Hi Arika,
The drivers that you need to install to make your executable work depends on what your executable is doing. To get started, you need to have the LabVIEW Run-Time Engine installed on your target machine (the Win2000 machine you are planning to use) in order to run your executable. Next, you need to determine what drivers your executable uses, if any. For example, if you are using GPIB instrument control, you will need to install the NI-488 drivers on your target machine. If you are performing data acquisition, you will need to install NI-DAQ drivers. If you are doing image acquistion, you will need to install NI-IMAQ drivers.
All these drivers are available for downloading on ni.com. To get the drivers, go to ht
tp://www.ni.com/support , click on the link that takes you to Drivers and Updates (under Option 3), and click on the links to get to the driver(s) you need. For example, if you need the LabVIEW 5.1.1 Run-Time engine, click on the All Drivers and Updates by Application link on the main page (http://www.ni.com/softlib.nsf/). Then click on the LabVIEW link, Windows 2000, Run Time Engine, and then you will see the link to get to the page to download the LabVIEW 5.1.1 Run-Time Engine.
I hope this information helps.
Best Regards,
Wilbur Shen
