I have a question about waveform chart or graph
Hi
I have a question about waveform chart or graph.
I'm using sound level meter, and I want express it in labview graph or chart.
I want fix x-axis 0~2000 and want show y-axis's value  every second.
Is there anything solution about it?
(1,216 Views)
Yes, you can fix the x-axis and update a graph at 1/second if your instrument allows. We'd have to see what your data looks like, but an XY graph would probably be appropriate.
(1,176 Views)
Well you can graph and present your data anyway you want, that's the easy part.
Acquiring the data is usually the hard part.
So I have to ask how you plan on getting the data from the sound meter into LabVIEW?
=== Engineer Ambiguously ===
(1,168 Views)
