I have a question that how to run labview developed software on a QTP(Quick Test Proffesional)
Hi all,
       I have a Labview developed demo tool and i  am trying to use QTP (Quick Test Pro, the HP functional test tool similar to Winrunner) to recognize the Labview tool. But it is unable to do so. Can you help me with the solution to this?
(2,587 Views)
How are you trying to 'recognize the LabVIEW tool'? You should describe your method to us. One way of calling LabVIEW code in other environments would be to create a DLL in LabVIEW and then call this DLL. Let me know if that's what you want to do and we can help you find links on how to achieve that.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,570 Views)
thanks for the reply..i am calling the Labview tool by creating the dll's and communicating with their software through the virtual com port.i tested our labview tool on  fuctional test tool "Winrunner" and it works fine but i am not able to test over QTP Hp which is also a fuctional test tool.
(2,568 Views)
