I have a "not enough memory to complete this operation" error message (with no error code) with tcp/ip Vi's. Also screen does not refresh.
Yes. If the packet length is one, the system crash, but with packet length more than four the same problem occurs.
Message 11 of 12
(617 Views)
boxer wrote in message news:<50650000000500000068870000-1023576873000@exchange.ni.com>...
Possibly somewhere down in the code perhaps in National Instrument's
TCP/IP VI's themselves, from time to time an attempt is being made to
read or write an array or access an array index with a negative number
of bytes or a negative array index. The error message you are
describing sounds very similar to the message you get if you try to
dimension an array with a negative number of elements. Because of
ones-complement math, A -1 index becomes 0xFFFFFFFF about 4.2 billion
if treated like an unsigned number. When
something tries to create an
array this large it will generally crash.
Doug D.
ddeclue@bellsouth.net
Message 12 of 12
(617 Views)
