I have a requriment to use both LabView and OPTO22 Ethernet B3000 brains. Where may I obtain VI's to interact between LabView and OPTO22 B3000 brains?
The LabVIEW industrial automation OPC servers cd has Mistic Optimux as well as Modbus protocols. So, if the Enet version of the B3000 can talk to these then you would need to contact NI's sales department to get the CD.
The B3000 RS-485 uses the Optimux and Mistic.But if the ENet version uses something different you still may want to check with your sales person to see if they have the correct protocol.
Doug
(2,708 Views)
The OPTO22 Ethernet B3000 Brain uses TCP/IP. It is a progression from the B3000 RS-485 and uses the same chassis and IO modules. Thanks for the excellent answer. I'll see what NI's sales department can offer.
(2,708 Views)
