I have an Hreels VI that doesn't work correctly
THis is the VI that I was given to look at and determine why it is not ramping correctly? I will post it so others may look at it and see if they can detect problems with it. I will get more information about the incorrect ramping in the next couple of days.
Thank you for your time
Jeremy Karr
(2,505 Views)
Try using the ms tick count to measure how often you are updating your output.
I suspect your code is iterating as frequently as you would like.
Check out the examples that ship with LV. They will show youhow to effect a ramp.
Ben
(2,505 Views)
With all of the nested sequence structures it's kind of hard to follow but one thing I noticed is the VI you're using (AO Update Channel (scaled value).vi) calls AO Config for every iteration. I don't think this is what you want. You might want to use AO Write One Update (scaled array).vi directly or modify the higher level VI to give you a connection to the iteration terminal.
(2,505 Views)
