I have an array here numbers are coming continuously, I have to make a table of number and repeition (frequency) of the number
(3,087 Views)
So?  It is not clear what exactly you want to do.  Nor is it clear what problems you are having (other than asking us to do your work for you).  Why don't you try to solve this problem yourself, and if you get stuck, show us your code, tell us what questions you have, and someone will surely help you.
BS
(3,085 Views)
When I read that message, I see the word "histogram".
That might be worth searching on.
(3,056 Views)
You can convert the numbers to strings and use variant attributes. Check out this thread.
(3,037 Views)
