I have an array of clusters of 4 numeric indicators and i want to plot 2 of them in a xy graph for the entire array? How can you seperate out 2 of the indicators of each cluster for the entire array
I have keithley 238 SMU, which when used in sweep mode returns the value in a array of cluster of 4 numeric indicators of which 2 are voltage and current and other two are step size and delay....I want to plot
I-V curves, how to do that?
(2,744 Views)
Hello aby
this could be a possible solution to separate 2 values from an array of 4 elements clusters an create 2 arrays suitable for graphing.
Hope it helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,744 Views)
