I have built a VI and then I used it as subvi it works but the front panel of subvi didn't diplay for other options
Kindly suggest me possible errors
timmy
(2,924 Views)
Hi timmi,
                If you are using a VI as a sub VI,the subVI controls and indicators receive data from and return data to the block diagram of the calling VI.So if you want to display anything other you can provide it in the calling VI.Is this you are asking about?
Thanks as kudos only:)
(2,922 Views)
Thanks for your reply......My calling VI just needs the results of subvi as it is calling many sub vi's and evry subvi is itself a another module containing many tests and selection panel for them so that user can select the desired option...  So i want it appear as new window so that user can select the appropiate values.
timmy
(2,907 Views)
Accepted by topic author PakAsia
Go to the VI Properties, choose Window Appearance.  The simple route would be to just use the Dialog setting.  But you can play around with the customized settings too.
(2,905 Views)
Thanks crossrulz... it worked
timmy
(2,886 Views)
