07-15-2004 02:28 AM
07-15-2004 05:24 AM
07-15-2004 06:08 AM
07-15-2004
08:00 AM
- last edited on
11-13-2025
03:27 PM
by
Content Cleaner
Below are links to various tutorials, examples, and app notes to help you with VISA events and instrument status registers.
Interative tutorial on VISA and instrument status registers
LV Examples using VISA and instrument status registers
App note on using instrument status registers and service requests in LabVIEW
07-15-2004
08:43 AM
- last edited on
11-13-2025
03:28 PM
by
Content Cleaner
And just to state the obvious, you might want to check ni.com/idnet to see if we've already written some VIs for your instrument that do this for you.
If you don't find a driver there, you can use a similar driver as an example, along with the helpful information that "Noel" posted.
You can also post a message asking if anybody else might have already written VIs for your instrument. What instrument are you using?
Brian
07-15-2004 10:36 AM
07-15-2004
12:01 PM
- last edited on
11-13-2025
03:28 PM
by
Content Cleaner
If I'm not mistaken, the 70004A is a display part of a "modular measurement system", and that you have other components that plug into it, such as a 71400C.
My point is that you might search for drivers for the other part numbers in the system, too.
I hope this helps, but I wouldn't be surprised if you will be developing your own VIs to do the communications. When you are done, I encourage you to share your VIs by submitting them back to the Instrument Driver Network, so that others can share your work.
Brian
