I have errors trying to get a picture with LabVIEW.
On the property node, there are a whole bunch of different choices that I can choose from if I right click the node. I know that the camera is capable of supporting up to 32 bits of pixel data. I have a PCI-1424 IMAQ card and a Kodak KLI-2113 board I changed the camera chice to Linescan but I don't know what to wire it to. I also tracked down some VI errors, but I don't know why they are happening They are in red. The main VI the Color Snap in picture control.vi goes has errors in the IMAQ Attribute.vi and the IMAQ Configure Buffer.vi. I mean there are errors all the way down, I just went to the 2 deepest Sub Vi's where I found the errors comming from. You have to click on the specific ones I s
ent you to see all info for those ones. For some reason it doesen't come up if you just go in the main VI the Color Snap in picture control.vi
Thanks for any help you can give me.
Brian
(2,614 Views)
Looks like a problems with connection between camera and framegrabber.
Do you have image in Measurement and Automation Explorer? At the first you must get snap and live images without any errors in MAX.
Is Kodak KLI-2113 supported by NI?
(2,614 Views)
Andrew,
I do get an image on MAX, and I don't know if the KLI-2113 board is supported by NI, but it works in MAX and with the Kodak board driver that I had. Even with the Cohu driver that is imported with the NI software, I can get an image on MAX but still do not get one through a VI. Any ideas?
Brian
(2,614 Views)
