I am trying to read from an excel spreadsheet and write these numbers into a two dimensional array. It connects and does not throw any errors but when I add probes to it, neither the array size nor the data is correct.
When i run it, I get 12x4 or 12x5 or 12x6.... and the numbers are always zero. I know the file exists, so are there some settings in excel that I must change?
Thanks in advance for your help.
Ron Deavers, CLD
