Hello;
When you install NI-DAQ you have an option to select the support files for the programming language used. On that point, you need to choose the support files for Labview 5.0. Otherwise, you won't see both the DAQ VIs and the Data Acquisition examples for Labview.
Hope this helps.
Filipe
