I have problem with reading sht30 temp/humidity sensor
Dear all, I have a setup that works with a Sensirion sht30 sensor and want to get humidity and temperature
I use an Arduino board and Linx library that work properly.
my problem is how to set commands for "i2c read" and "i2c write" blocks to get humidity and temp.
I had made a file for monitoring the sht20 sensor and it was ok, but I couldn't change it for sht30. datasheet of the sensor is attached.
I would be so appreciated if anyone can help. thanks
(2,325 Views)
What code did you write for the SHT20?
And why doesn't it work for the SHT30?
(2,277 Views)
hi, thanks for your response.
files related to sht20 and sht30 were attached.(ver:2020)
(2,256 Views)
Hi, were you able to solve your issue?
(2,141 Views)
Any update for SHT30?
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
(2,096 Views)
