I have problem with running excel macro in report generation tool kit
I am trying to use Excel Run Macro.vi but run into a problem: Exception occured in Microsoft Excel, The macro 'personal.xls!Macro1' cannot be found.. Help Path is C:\Program Files\Microsoft Office\Office\1033\xlmain9.chm and context 0 in Excel Run Macro.vi->example.vi
Also I tried to save the macro under the file that is active and I get the same results.
I saved the macro as *.bas file and ran it using Excel Import Module and did not see any erreos and it did not do anything.
Where a re some god examples that use the excel marco feature using the new report generation vis?
(2,962 Views)
masoud,
I just wanted to make sure that you saw my response to your previous post on this issue.
Link to previous post.
Randy Hoskin
http://www.ni.com/ask
(2,961 Views)
Did this ever get solved?
I have the exact same problem.
(2,602 Views)
