I have problems with front panel butttons on a published exe.
I have built and published an embedded LabVIEW 7.1 exe and (finally) controlled it from another PC using Internet Explorer. But two of the buttons on the FP don't work correctly. One shows on the web as enabled although it is disabled. The other button has the opposite problem.
(3,219 Views)
By 'embedded 7.1 exe', are you referring to LabVIEW Embedded or to a LabVIEW Real-Time application you have deployed to a National Instruments Real-Time Target?
(3,187 Views)
Hi B O B,
This is a LabVIEW executable installed on a PC, not a real-time target.
(3,168 Views)
I believe this KnowledgeBase will answer your question:
http://digital.ni.com/public.nsf/allkb/7F2D399B61927A4786256FDD0040CE74?OpenDocument
Cheers!
(3,146 Views)
Thanks B O B, that looks like the answer.  I appreciate your help.
(3,144 Views)
