I have replaced an index array numerical control with a menu ring. Is it possible to programmatically populate the ring menu?
LabVIEW 7.1 Developer
I have replace the numerical control on the array index with a menu ring. I would like to know if it is possible to programmatically populate the menu ring text when it is used as the index selector ?
Ryan
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(3,543 Views)
Yes, create an array of strings and feed them to the "strings[]" property of the ring. See attached example (LabVIEW 7.0)
(3,528 Views)
Hi Ryan,
I would like to know how you replaced just the index of terminal an array with a ring control. Did you mean to say that instead of using the array index terminal you used a seperate ring control with which you changed the array index?
KAliDas
(3,520 Views)
That was the easy part. I found out how to replace the Array Index (which is a numerical control) from another thread on this development board, http://forums.ni.com/ni/board/message?board.id=170&message.id=16296&requireLogin=False
The next thing I wanted to do was to populate this menu ring control with text I am getting from somewhere else.
(3,500 Views)
With the control being attached to the Array - it won't let me create the property node for the menu ring.
I think I will try and populate the type def of the menu ring that is used in the new edited control that I created and see if that works. I will make sure I have AutoUpdate from TypeDef enabled.
(3,500 Views)
I think that menu ring typedefs will not get updated if you add/delete items in the parent control. You may have to use enum, but I tried it seems that one cannot replace array index terminal with an enumerated control.
KAliDas
(3,479 Views)
I tried it and it did not work.
I worked around it with simple code to do the same thing as I was trying with the Ring Menu embedded in the Array control. Thanks for the replies everyone.
(3,457 Views)
