I have the PCI-6602 device and it works with my others programs.
I downloaded the file : LabVIEW Express AI Using External Sample Clock (Scan Clock) from an NI 6602 from this website. but I get the message error :Error -200220 occurred at DAQmx when I run it.
(2,507 Views)
Check to make sure your device is present in the Measurement and Automation Explorer under DAQmx devices. You may have configured the device/chassis in Traditional NI-DAQ and not NI-DAQmx. Also check your device ID or string identifier to make sure that it matches with the ID in MAX.
Hope this helps,
Nick
(2,507 Views)
