I have tried to connect NI Austin Weather Station use Dial-up internet conection, but I am not able to see data in live.
Iam reading the Book "Internet Applications in LabView", in the chapter 5 page#130 explain how to connect with Weather Station. But, when I tried to run the VI Weather.vi I did not get request from your server because all display are in zero. My internet connection is Dial-Up, I do not if this is the problem. Thanks in advance.
(2,960 Views)
Are you running the shipping example called DS Weather.VI or did you write your own program? I just tried the LV 5.1 version shown in the book and the LV 6.1 version and they both work. I don't think it matters that you have a dial-up connection. It might be a little slow but it should still work.
(2,960 Views)
Mine works too...even from North Pole, Alaska, where we still use TCP/ss (Transmission Control Protocol over Smoke Signals. 🙂
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,960 Views)
