‎07-05-2005 09:41 AM
since you have the runtime engine 7.0 already installed, check the access rights on the ..\\national instruments\shared folder. the operator should have full access rights to this folder
‎07-05-2005 10:08 AM
‎07-05-2005 10:19 AM
‎07-05-2005 10:23 AM
@sheldon Stokes wrote:
This brings up my biggest wish, which is to have real genuine stand-alone executables from Labview. Having to install a multi-meg environment on each target machine isn't very satisfying. If I could produce real stand-alone code, I'd uninstall my other compilers, and be a real happy camper.
‎07-05-2005 10:33 AM
‎07-05-2005 10:35 AM
Raghunathan,
Could it be that you have not installed NI-DAQ on your target machine?
Whilst the Application Builder can create an installer that optionally includes the LV Run Time Engine, but it does not install NI-DAQ.
NI DAQ has to be installed seperately - normally using the CD that comes with DAQ hardware, or download the (large) NI-DAQ from NI's web site.
You may also need to seperately install additional NI drivers for other hardware capabilities, such as GPIB and VISA if used.
Mark H.
‎06-09-2006 02:25 PM
"Thank you all~
But the thing is I did include the run-time engine by checking the option in "advanced installer settings". Even with a simplest program, I still have the trouble."
I DONT HAVE THIS OPTION "advanced installer settings"‎06-09-2006 02:48 PM
I assume you/ve done (1). For (2), just righ-click on the "Built specification" in the project window and select: "New...installer".
Here you specify what to install, including runtime engines, etc. Look for the setting under "additional installers".
‎06-10-2006 11:15 PM
