I realized that property nodes used is not supported by a PDA. I am trying to use event structure without these. Is is possible to make labview read the buttons when selected, without using property nodes?
I also tried polling but I am able to complete the Prgm only if I use a cluster which is not PDA compatible
Pls give me ideas to use event structures w/o property nodes but at the same time make labview read when buttons are selected.
