I have used the write jpeg file from intensity but image colours are different
Here are the relevent files for my program.
Insert these values
x1=218
x2=368
y1=45
y2=45
r=39 in order to run adn crop the pictures
I hope someone can help
(2,728 Views)
I'd suggest you to use PNG format to save the images of your intensity graphs. You get sharper images than JPEG format.
I made some modification to your program to save PNG files, anyway you can try to save in JPEG and see the difference.
Alberto
P.S. I removed the delay of 100ms from the final Equation with kl fator.vi, the speed is much increased.
(2,728 Views)
Please can you save this as a version 6.0 file as I do not have version 6.1. thanks
(2,728 Views)
Here it is.
Alberto
(2,728 Views)
