02-04-2003 10:13 AM
02-04-2003 05:36 PM
02-05-2003
09:17 AM
- last edited on
11-11-2025
10:59 AM
by
Content Cleaner
You could also try running one of the serial example VIs that ships with LabVIEW. Place a loop in it to run similar to yours and then see if it quits. If so, then the problem is probably not with your code but with the hardware itself. This always helps me to find the source of the problem. Also, try running a loopback test if you think you might have hardware problems.
