I how to save an array to a text file?
@freddearaujo wrote:
How can I save a array with 3 or more dimensions? Is it possible?
It is possible.  It is just a question of how do you want the text file to look in the end.
Message 11 of 25
(5,996 Views)
My objective is save the array in some kind of file so I can read it in another VI as the original array.
Message 12 of 25
(5,990 Views)
"Array to spreadsheet string" has defined handling of higher dimensional arrays, so just use it and save the resulting string to a plain text file.
To read it back, just read it as a plain string, then use "spreadsheet string to array" to recreate the N-dimensional array.
Why does nobody ever read the help?
Personally, it makes little sense to do this. I would recommend to store it in a binary file instead. Much more efficient, with the disadvantage that it is not readable by the typical humans. 😄
Message 13 of 25
(5,989 Views)
What typical human could read a multidimensional array anyway?
Lynn
Message 14 of 25
(5,980 Views)
If you don't care about reading in a text file, the definately just use the Write Binary File function.  It will make this task very simple.
Message 15 of 25
(5,978 Views)
A sorted set of printed pages, each containing a 2D table, is a perfectly readable 3D array. 😄 Now make several such sets and place each in a binder and you have a 4D array. 😄
Message 16 of 25
(5,975 Views)
You and I understand that. I asked about a typical human.
Lynn
Message 17 of 25
(5,962 Views)
Yeah, because us knights are kind of crazy.  Even still, I would not want to look at a 3D array in a text file.  It is bad enough with multiple pages in Excel.
Message 18 of 25
(5,959 Views)
Well, you are probably to young to remember entire books with logarithm tables. 😄 (I guess you've never used a slide rule either).
Kids these days!
Message 19 of 25
(5,953 Views)
Kids these days!
I have actually used a logrithm table.  I think it was in high school physics (or was it 6th grade math?).  But the slide rule is something that has eluded me.  I can recognize one, but have yet to use one.  If my father ever finds his again, I have laid claim to it.
But at least I remember LabVIEW before the project!
Message 20 of 25
(5,946 Views)
