I just discovered the coolest thing
While holding the control key, I happened to have my cursor over a division node on the block diagram and it changed to a weird looking figure-8 with an arrow. I think I've seen this before, but I never explored what it was. I clicked, and like magic the 2 wires that I had connected to the node switched places!
Maybe this is common knowledge, but I felt the need to post it because I never knew it existed and I'm sure there are others out there like me. It's quite convenient as opposed to deleting wires and reconnecting.
Almost 2 years and I'm still learning these little tidbits all the time.
Message 1 of 11
(4,020 Views)
Nice thing to know.... maybe should convert this post to a nugget 🙂
Norbert B.
Norbert
Expert: Geometry
Message 2 of 11
(4,004 Views)
HI,
I am interrested at using this tool but maybe because of my french mother tongue I haven't succed yet to understand the trick,
is that working on all wires connected to a sub VI or a node like an user event register VI ? maybe it doesn't work under labview 7.01
how should I do exactly,
thanks
Olivier
Message 4 of 11
(3,990 Views)
Didn't mean to take anything away from Darren's nugget, I don't remember reading that one. I did a quick search, but of course I didn't include "switcharoo tool" in it Smiley Very Happy
Message 5 of 11
(3,983 Views)
Olivier,
It only works on nodes that have 2 inputs, like the numeric operations (add, subtract, etc.). Wire both inputs, then hold control and move your cursor in between the 2 inputs until it changes into an arrow with a figure-8. Clicking will swap the 2 inputs.
Message 6 of 11
(3,978 Views)
Yeah, someday search algorithms will be able to read our minds and say "Oh, that's what you really wanted!". For now, we have to keep guessing. I remembered the nugget, but my first search for "swap nodes" didn't turn it up. For some reason, a search for "swap inputs" did. Go figure.
Message 7 of 11
(3,973 Views)
Another nugget that has been posted that I use all the time ctrl-wheel mouse in structures.  You can then switch between events and case fast and easy using the wheel mouse.
Message 8 of 11
(3,948 Views)
Wow.
I didn't know that one Evan -- Thanks.  I'll use that often!
Tom
Message 9 of 11
(3,938 Views)
Yeah I scroll through structures like that hundreds of times a day. I mostly use it to move back and forth to make sure everything is lined up in the different cases. I'm a bit of a perfectionist and it definitely spills over into my LV code appearance.
Message 10 of 11
(3,931 Views)
