I keep getting an error trying to open labview 7.1, and I am really confused. screen shot and log included
For some reason, recently I have been getting problems trying to run labview. It all started when I upgraded from labview 6 to labview 7.1.  I even went as far as to re-image a brand new machine with XP and start over again.  I'm still getting issues.  What do you think?  Can a virus cause problems like this?
Thanks for your help, I really appreciate it
(2,601 Views)
Hello!
Sorry to hear you are experiencing problems with LabVIEW.  This error dialogue is a result of some error causing Windows to shut LabVIEW down.  This is a little different than an internal LabVIEW error which usually results in an error message with a .cpp file/line number.  I don’t really know how to decode the MS error log file, but what I see it looks like you are doing quite a bit of complicated programming.  I see references to quite a lot of the more advanced LabVIEW programming items (such as dlls, mathscript, images, and storage).  I highly suspect that the crashes are occurring somewhere in external code, but without more info on your program it could be hard for me to diagnose.  Could you provide us with a little more information about your application?  Also, it would be great for troubleshooting if you could reduce the crashing VI as much as possible so that we can see exactly _where_ the crash is occurring.  This could shed a lot of light on the problem.
Also, if you are doing some mathscript stuff, don’t forget to check out: http://digital.ni.com/public.nsf/websearch/4475BC3CEB062C9586256D750058F14B?OpenDocument in case any of this pertains to your system.
Thanks for posting to the NI Discussion Forums!  Please let me know how it all goes-
Travis M
LabVIEW R&D
(2,567 Views)
