I like to be able to control an external application (Specifically ICQ)
I like to control ICQ, a web based massaging application. (Http://www.ICQ.com). My knowledge of ACTIVE X is very limited so if some one can recommend a web page that explains ACTIVE X at a very beginner�s level I will appreciate it. Also if some one could mention what sort of information I need from ICQ to enable me to do that it will be very helpful.
(2,636 Views)
Greetings!
Indeed, ICQ does have activex variables available to Labview. Open up a Labview front panel Activex Container, right click on there and insert an object...ICQ has three listed. This should give you a start.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,636 Views)
Greets Chutla
Thanks for the speedy reply. This is very help full. It is enough to get me started.
(2,636 Views)
