I lost "New Report.vi"
I've noticed that there has been various issues in regards of NIReport.llb when creating executables. I'm on my way to resolving mine, but I somehow lost New Report.vi. When I go to NIReport.llb, I can see New Report.vi, but it is empty. I click it and it says that it wasn't found. When I select it from the functions window, nothing happens.
Is there a way to get it back? I'm using Labview 8.6, if that helps.
Jose
Message 1 of 8
(3,821 Views)
Repair LabVIEW would probably solve the problem. see this link http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001
Message 2 of 8
(3,813 Views)
lacVIEW
Thank you for your responce.
Does it have to do a Full Repair? I did it with just the Report Generator Toolkit, and it didn't solve it. I also did it with a full repair of LV 8.6, but I couldn't find the distribution .id or .xml file of LabVIEW 8.5. I'm not sure why it looks for the distribution of LV 8.5, but so far is this is what is holding the process to do a full repair.
Jose
Message 3 of 8
(3,791 Views)
Ok,
I got the New Report.vi back, but I'm still getting errors. This time it says the the VI's are not Executable... what does that mean?
Jose
Message 4 of 8
(3,772 Views)
This thread might help.
http://forums.ni.com/t5/NI-TestStand/LabVIEW-The-VI-is-not-executable-Most-likely-the-VI-is-broken-o...
Does this happen in the Development environment or on the runtime machine?
Message 5 of 8
(3,767 Views)
Thanks for the thread,
This is happening in the development environment.
Jose
Message 6 of 8
(3,762 Views)
Can you post the VIs to see if I can get them to open or recreate the error?
It might also help to see a screenshot of the error that you are getting.
Message 7 of 8
(3,759 Views)
Sure,
I've attached the VI's and a screen shot of the error list.
Thanks for the help,
Jose
Message 8 of 8
(3,752 Views)
