I´m from Brazil and I would like to know if I can use the Labview and other National technologies to create a building/home automation (energy, water, lightning,...)? Which would be a ideal project? Which equipments should I use?
National Instruments does not support Home Automation at this very moment. Can you use LabVIEW and other NI products for building/home automation? Certainly you can but the question is; is it cost effective? I don't think so. If I was going to do it, I would probably use LabVIEW due to it's flexibility and the fact that I know to program in LV but as far as Hardware, I would shop around.
(3,045 Views)
I agree with you regarding Hardware! On the other hand, using the Labview, which kind of data acquisition I need? Do you have any idea?? In my thoughts, I would have the sensors, a data aquisition(???) and the Labview in a personal computer screen.
Thanks a lot !!
(3,045 Views)
Thanks a lot !!
(3,045 Views)
I could help you better if you had an idea of the equipment you will be controlling or reading to/from. Are you planning to totally customize a system or are you looking to use instruments/controllers already available for Home Automation? Im not sure I understand what you really need. Here's an Idea. Computer is the controller of the system.
System consist of Light Control Only (to keep it simple). Program written in LabVIEW. Here you can create schedules to turn lights on/off/dim. Then LV could communicate, (for example using X10 or other protocol), commands to the device actually controlling the lights. Lighting device could be controlled using some sort of communications like, X10, Serial, IR, RF, Ethernet, etc... So this system can turn lights
on/off/dim% either at the click of a button on your screen or a timer. Adding any other system in the house will more than likely require a different communication protocol and complicates things even further. You could much of this with regular automation hardware from NI but this requires integrating different components like relays, dimmers, etc.. Much more work and more expensive, (I would think), than buying a device made specifically for the system.
I hope this helps.
(3,045 Views)
I did a quick google search and found VIs for download at
http://www.vicontrols.com/download/download.htm.
You might do your own search and see what turns up. I do know some
people that have written their own set of X10 VIs, but if you can find
some that will get you started that much quicker.
Greg McKaskle
(3,045 Views)
