I'm getting an error Starting up FGEN-SFP
I'm getting an error starting up NI-FGEN Soft Front Panel v1.4. On the splash screen that starts up with the application, in the midst of loading NI configuration manager, the following error appears: "NI-FGEN for DAQ 2.0.0 or higher was found, but it could not be loaded. To run this software you need NI-FGEN for DAQ 2.0.0 or higher"
I'm running on Win 2000.
(3,281 Views)
It sounds like there may have been a problem with the NI-FGEN install. I would suggest re-installing the NI-FGEN driver and seeing if that clears up the error.
Here is the link to the 2.1 driver.
NI-FGEN Version 2.1 for Windows 2000/98/ME/NT/XP
NI-FGEN Version 2.2.1 for Windows 2000/NT/XP
Evan
Message Edited by Molly K on 02-18-2005 11:58 PM
(3,282 Views)
My problem was fixed by logging on as an administrator or power user - if you are a normal user under network properties, FGEN doesn't start properly.
(3,281 Views)
