Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I'm getting an error - VxD NIPALK(01) when trying to output a 5 second tone through LabVIEW and AO...a 2 second tone is no problem.
lynneh
Member
04-25-2002
10:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using LabVIEW 6i, Windows 98, and a PCI-MIO-16E-4 board which is supported only by earlier versions of NIDAQ. Any suggestions?
0
Kudos
Message
1
of 3
(2,739 Views)
Reply
Re: I'm getting an error - VxD NIPALK(01) when trying to output a 5 second tone through LabVIEW and AO...a 2 second tone is no problem.
Filipe A.
Active Participant
04-26-2002
10:23 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello;
To give you better advise I would need more details about the signals you are trying to output to the analog channel of your DAQ board; such as update rate, frequency of the signal, number of channels, etc.
Regards
Filipe
0
Kudos
Message
2
of 3
(2,738 Views)
Reply
lynneh
Member
Author
04-26-2002
11:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I am sending a single channel of 5 kHz for 5 seconds at a rate of 44 k/s. The buffer size is automatically calculated at the time the tone is created.
0
Kudos
Message
3
of 3
(2,738 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
