I'm having problems using the PCI-4552 board with XP
The drivers have been installed, the card seems to read the information, but at the end of the cycle it shows an error. (error 7, non-existent board). why is this? do i need to go back to windows NT? Or have u got new drivers for the PCI-4552 DSA board for Xp?
(2,877 Views)
The current drivers (NI-DAQ 7.1 and NI DSA v. 1.1.1) both work under XP. Which function call is returning the error? Are you just making DAQ calls, or are you also making NI-DSA calls as well? Do you know if you are using the on-board processor at all?
(2,877 Views)
i am making DSA calls, and the read function returns the error. i'm not sure if i use the on-board processor. But in windows NT i did not get any errors.
(2,877 Views)
Try running the shipping examples to see if the same problem occurs. If not, then there may be something in your code. If the same problem occurs with the shipping example, go back to Measurement and Automation Explorer (MAX) and verify the board shows up and passes the resource tests.
(2,877 Views)
