I'm having trouble communicating with a transducer (Keyence LS-3100 laser scan micrometer) via the serial port. It works in Hyperterminal. Any suggestions?
Its not a simple baud-rate or parity error. If I issue the command to send data (X1) in hyperterminal I start to get data. If I then switch to Labview I still get data. However if I try to issue the send-data command via Labview I get nothing (i.e. I can read from the device, but not write to it).
I am on a Windows 98 (version 2) PC, running Labview 5.1.1
(3,393 Views)
Try adding a carraige return to the end of your command.
"djb" wrote in message news:506500000008000000711E0000-986697009000@quiq.com...
(3,393 Views)
I'm afraid its not that simple. I've tried the command both with and without a carriage return. Capitalized and not capitalized. No response.
(3,393 Views)
When I get to where you are at right now I "spy" on the serial port to
see exactly what is being sent back and forth. You are fortunate that
you can get it to work with HyperTerminal, you can use it to create
a known good message and watch the response coming back.
Try
http://www.sysinternals.com/ntw2k/freeware/portmon.shtml
http://www.fte.com/products/stspy95.htm
or other similar products.
"djb" wrote in message news:506500000005000000D8290000-986697009000@quiq.com...
> response.
(3,393 Views)
Try changing the hardware flow-control settings e.g. DSR/DTR and RTS/CTS
Good luck
Keith
(3,393 Views)
