I'm having trouble with D4.1 in Labview '09. It says to determine someone's age in years, when given current month,day,and year, and the person's birth month, day and year
Given someone's Birth month day and year....and also the current month day and year...as inputs....calculate their age, in years...as output....age should not increment by one until their birthday arrives that year.   I just cant get the coding right...please help
Message 1 of 28
(4,828 Views)
What have you done so far? Show us what you tried and explain where it fails
What's "D4.1"?
The "Date/Time to Seconds" function will be helpful to you.
Message 3 of 28
(4,809 Views)
Subtract the birth year from the current year (four digit format) to get preliminary age.  Then check the date (if current month/day is less  than birth month/day, subtract 1 from age). should only require a few math steps and a case structure.
Message 4 of 28
(4,787 Views)
Just subtract the two date/timestamps.  Then round down to the year.
Message 5 of 28
(4,785 Views)
@nathand wrote:
[...] What's "D4.1"? [...]
That's the number of the homework assignment.
Jim
Message 6 of 28
(4,776 Views)
thanks for your help...I'm new to lab view and am unfamiliar with a lot of the functions.  I was using a select function. If the current year > the birth yr, then Current-birth.  that worked.  but as i try to connect the months and days into it , thats where my issues are coming up...I'm still not getting the outcome i want. Thanks
Message 7 of 28
(4,769 Views)
Subtract the years from each other than subtract 1 to get age
Then
If current month is greater than birth month then
  age=age+1
Elseif  current month is equal to birth month AND current day is greater than equal to birthday then
  age = age +1
Else
  age is what you got in the first step.
end if.
Message 8 of 28
(4,756 Views)
It's called a Case Structure.  It has an input terminal which you can wire.  one piece of code inside the structure runs base on the value wired to the input terminal.
Message 10 of 28
(4,739 Views)
