I'm not getting proper output from my LABVIEW/Simulink interface.
I have a simple Simulink model. I 'm using a slider gain to control input to a polynomial block. I have (2) NIsinks. One for the slider output and one for the polynomial output. I get no output from the poly sink. The slider output interfaces just fine.
(2,512 Views)
I downloaded your code and did see what you are reporting. However, I noticed that the SIT Toolkit code that was generated looked incorrect. I deleted all of the code and then made new indicators and started the process over again. The attached code works correctly for me. Please contact support or respond to this post if the code I am attaching is not working or if you encounter further issues.
Robert Jackson
Application Engineer
(2,512 Views)
