I'm working on DC Motor control using DAQ. There is sufficient voltage output from DAQ but not current. What should i do so as to drive the motor
I'm working on DC Motor control using DAQ. There is sufficient voltage output from DAQ but not current. What should i do so as to drive the motor. Could you suggest me appropriate driver IC using which this problem can be solved.
Saravanan.T
(2,500 Views)
Hello ,Saravanan.T
What kind of controll board are you using for driving the motor?
(2,497 Views)
You really should use a DC motor controller to control a DC motor, look at the 754410 IC for a good example. You should be able to interface these to most DAQ devices.
Alan
(2,465 Views)
