I meet a Bug when in insert ActiveX of Excel
I find a bug when I insert ActiveX of Excel into LabVIW 8.5.1. -- ¤╭⌒╮ ╭⌒⌒╮ ╱-◥██◣ ╭ ╭ ︱田︱田田| Boone Mail:boone301@126.com QQ:24732458 QQ Group(LabVIEW_Home):13267790 QQ Corporation:17756234 ╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬╬
Message 1 of 12
(5,895 Views)
Sorry we dont understand that language.Smiley Wink
Message 2 of 12
(5,894 Views)
Hi Boone301,
can you explain a bit more in detail? When do you get the bug? What do you insert into Excel? Why do you think it´s a bug, what happens?
Mike
Message Edited by MikeS81 on 08-25-2008 03:44 PM
Message 3 of 12
(5,889 Views)
Hi, you can paste a screenshot to describe your findings, and I also introduce the Excel Macro Example.vi, this example can help you learn how to deal with ActiveX.
Best wishes,
Message 4 of 12
(5,858 Views)
Peterpan,
Have you forgot the attachment?
Edit: Oops sorry just now understood that its in Examples Finder.
Message Edited by mathan on 08-26-2008 04:08 AM
Message 5 of 12
(5,854 Views)
Sorry, Mathon.
I didn't see any attachment in your reply.
Message 6 of 12
(5,827 Views)
Dear all,
As the picture.
Boone
Message 7 of 12
(5,817 Views)
Hi Boone,
Whenever you wanna use ActiveX to get the method or properties of the object, be sure to use the Automation Open.vi first, then use the output reference to call the objects' property or method.
Best wishes,
Message 8 of 12
(5,813 Views)
Peterpan wrote:
Hi Boone,
Best wishes,
That is only necessary if you need to instantiate the ActiveX object programmatically. Clearly the user has an ActiveX container, so the object has already been created, and Automation Open is not necessary and would actually provide a separate object alltogether.
To Boone: What kind of ActiveX object did you insert in the container? I can't quite tell from the screenshot.
Message 9 of 12
(5,786 Views)
Yes, I've open this AcyiveX. I can use this function in LabVIEW 8.2 and 8.6, but when I use in 8.5, my LabVIEW will close my itself.
Message 10 of 12
(5,755 Views)
