I need LV6 runtime engine for working some drivers
hello
I need LabView 6 runtime engine for the working of some instrument drivers
if it is having somebody please attach or give a way for getting this
thank you
"Thanks with regards "
by
..........Gireesh..........
Message 1 of 8
(3,620 Views)
Click on 'Support' and go to 'Drivers and Updates'. After your search finds it, download it.
Where did you find a driver that requires such an old runtime?
Message 2 of 8
(3,608 Views)
hello sir
It is downloaded from NI only but it was two or three years back.
any new driver is avalable or not?
OK I will ckeck it
thank you
by
Message 3 of 8
(3,601 Views)
I don't understand what you just said. Of course there would not be a new LabVIEW 6 runtime update.
Based on your other post, I don't see why you need the runtime at all. If you had actually answered my question, we would would know.
Message 4 of 8
(3,595 Views)
Sir,
Actually lambda PS drivers will not work without LV6 RTE. In one of my PC it is already installed. how it installed that i don't know. I am still searching for the RTE. I need to install this RTE to the second PC also. First time I run the lambda program, it was not worked. Later I remember that it due to the RTE6 only.
that is why I am asking the RTE 6 or 6.1
thank you
by
Message 5 of 8
(3,584 Views)
Why can't you simply post the link to the drivers you think require the LabVIEW 6 runtime?Only if the driver is a dll built with LabVIEW 6 do you need a runtime.
I also don't understand why your search for the runtime fails. I click on Support>Drivers and Updates>Download type>Run-Time. I then did a search for 'LabVIEW'.
Message 6 of 8
(3,577 Views)
sir,
I don't know about this.
At that time i tried with the RTE 6, it is worked fine.
That only I know.
 And i got the RTE 6 from drivers and updates. in the earlier post, i forgot to tell you about this
thank you for responding upto this level
thank you very much ( expecting more helps from you later also)
by
Message 7 of 8
(3,569 Views)
Message 8 of 8
(3,552 Views)
