Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I need a 2-channel 100MHx frequency counter
Jiggawho
Member
07-03-2002
01:20 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
What can I use? I need to measure the change in resonant frequency on a SAW device.
0
Kudos
Message
1
of 4
(2,784 Views)
Reply
Re: I need a 2-channel 100MHx frequency counter
Ben
Knight of NI
07-03-2002
02:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
How often do you have to make your measurements?
What kind of signal?
What kind of range?
How much delay between measurement and display of same?
Answers range from DSA hardware doing JTFA through freq counter read via GPIB to Freq to voltage converter monitored by sandard analog in device.
More info would be helpfull.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 4
(2,784 Views)
Reply
Tims
Member
07-03-2002
05:07 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Jiggawho,
Why not just a GPIB controlled Frequency meter?
Tim
> a SAW device.
0
Kudos
Message
3
of 4
(2,784 Views)
Reply
Filipe A.
Active Participant
07-08-2002
12:03 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello;
We will definitely need more information about the type of signal you need to measure.
1)Is the signal a digital TTL type?
2) How many inputs you will need?
3) Do you already have any NI Hardware?
Regards
Filipe A.
Kudos
Message
4
of 4
(2,784 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
