(I need a quick help) how can i collect voltage measurements from an unknown multimeter on a pc? (A Chinese multimeter)
Hello guys,
I’m really in trouble and I don’t know much about lab view. I have an megatek multimeter (mt-1941) which is a Chinese instrument without any support information.  I found that silicon labratories driver cp210x works appropriately with it and I could read and run * IDN? Command. But i don’t know how can I collect my continuous voltage measurements on my pc. The port is usb-midi (as i guess). I’m a material engineering student, so I don’t know much about these stuffs. I need a quick help.
Thanks a million
(2,694 Views)
Well you are up a creek without a paddle here...
If you can not find any documentation (A quick Google found nothing for me) the best you can hope for is that is uses an SCPI command set
Try something like sending the command  MEAS:VOLT:DC? and see if it returns anything other than an error.
=== Engineer Ambiguously ===
(2,640 Views)
