I need a suggestion for an architecture of an application
i intend to implement an architecture for a test bench at my work. I'm kinda confused and don't know which structure should i pick for my application. The idea of the test is monitoring the temprature of my stator and switch on and off with a constant voltage based on it's temp and eventually stop the fatigue test untill it reaches a maximum deviation in the ohm-resistance.
Any suggestion or issues i should be aware of? is the message queue handler a good option for fatigue checks ?
how can i prevent multiple same messages in mikro seconds areas ?
Thanks for any answer
(1,009 Views)
I'd start with the Simple State Machine. From what you've described, you can morph that into any of the other design patterns with little effort.
(976 Views)
