I need advice.
I want to do a Multi Chanel Analyzer (MCA)with Labview 7.0. It is similar to do an histogramatic graph of voltage.
My signal comes from an oscilloscope (Tektronix TDS540B with GPIB) and go to PCI DAQ card (NI 488.2 GPIB) in a system PC/Windows 2000.
I suppose that it already exists a *.vi to do something similar.
I need an advice and orientation. As you can see I am novice.
(2,879 Views)
Hi guilmar,
you need the instrument driver for your oscilloscope. You can download it here from the driver library.
You need access rights to the LabVIEW installation folders to instal the driver. There should be examples and a "Getting started" VI to give you a startup.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,870 Views)
Thank you for your answer. I will try to do how you have described and then I will tell you what's happening.
(2,847 Views)
