I need examples of reading USB port any simply read from there data
possible for instance consider given from Usb cameras?? there is example??
(2,735 Views)
Are you trying to use the USB ports on a Real-Time PXI controller? Or are you running in Windows? I suspect you are using the USB ports on a Windows-based PC. If that is the case, please search for your question in the LabVIEW General group. I know it has been asked before. If you don't find an adequate answer there, you might try posting the question again in that group.
In general, LabVIEW can talk to a DLL that interfaces to 3rd party hardware. That driver (typically a DLL) would be supplied by the hardware manufacturer.
(2,735 Views)
