I need help for esa S510
Dears I had problem esa S510 the operating system is corrupted it does not run and go to the application when start is read from bios then stop run and show error is: Phar Lap ETS Monitor.
it seem's like no operating system. Could any one help to get the operating system for esa S510.
Thank you.
(2,736 Views)
Can you explain how your question relates to LabVIEW? (you posted in the LabVIEW forum)
Have you tried to contact the manufacturer?
(2,703 Views)
Dear
I need some documents to learn what is Phar Lap ETS operating system and how can I download it and install?
Thank you
(2,656 Views)
Hi MOmer,
As altenbach said above, this is a LabVIEW forum post and the question doesn't seem to relate to LabVIEW. I would first suggest searching for Phar Lap ETS OS in the forum search bar or even Google to get more information. With a quick search in our forums, I was able to find this thread Create a Desktop Real-Time Computer Running Pharlap?
This may not get you the exact answer but it could help you find the next steps you are looking for. I've also included a KB Article that is discussed in that thread. How Do I Create a Desktop Real-Time Computer Running Pharlap?
Jacob C.
Applications Engineering
(2,636 Views)
