I need help regarding measurement of "time domain parameters of Heart rate variability" using labview.
Joanna,
It is probably better to continue posting here to the Forum. Many others watch the postings and often someone else will offer an important and useful suggestion.
Please be as specific as possible in describing your doubts about the document.
Lynn
Message 11 of 18
(1,678 Views)
Hi Joana
 Even I would like to have a look at the VI for HRV. Can you post the VI you have developed?
Message 12 of 18
(1,588 Views)
can someone please tell where is the data for 'all rows' coming from in RR DEMO 82.VI.is it a stimulated waveform?
kindly help.thanks in advance
Message Edited by iam on 03-15-2008 11:13 AM
Message 13 of 18
(1,559 Views)
Hi iam,
That data is just based on joana's ECG data that was acquired from Matlab, it is essentially a txt file that was posted.  Then this was taken into LabVIEW using read from spreadsheet file.
Message 14 of 18
(1,539 Views)
Am working on a similar project to RR Demo 8.2. Instead of the rows could anyone suggest me how I could use ECG signals acquired using DAQ 6009..
Awaiting your replies..
Message 15 of 18
(1,469 Views)
Hi Naveena,
Are you just trying to find a way to bring in the data from the USB 6009 to use with the RR Demo VI? If so, you could probably use the DAQ Assistant or other low level VIs found on the DAQmx functions palette (Measurement I/O » NI-DAQmx) to setup the configurations. You would use the values from the DAQ Assistant instead of using the All Rows array. I hope that helps!
Message 16 of 18
(1,424 Views)
Thank U Ms.Carla.
I currently dint have the DAQ 6009, so i tried it with Acquire sound and it worked well..
Hope it works the same with DAQ6009. Do you think it will work.
God Bless..
Message 17 of 18
(1,420 Views)
Hi Naveena,
You should be able to get it to work with the 6009. Let us know if you have any other questions. Have a good one!
Message 18 of 18
(1,404 Views)
