Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I need help to convert a (HEX 1.15) to a decimal file,and then plot it with LabVIEW.
him
Member
03-26-2001
01:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
0
Kudos
Message
1
of 2
(2,859 Views)
Reply
Re: I need help to convert a (HEX 1.15) to a decimal file,and then plot it with LabVIEW.
Doug C
NI Employee (retired)
03-26-2001
02:52 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The best way is to use the HEX to decimal coversion VI in the string pallette. Then, write this decimal directly to your chart. If you are doing it a point at a time put it into a while loop.
Doug
1
Kudo
Message
2
of 2
(2,859 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
