I need help w/ speed up parsing of spreadsheet string
Any ideas on how to make the attached vi any faster?  I have included an example of the input file as well as the two sub vi's.  Any thoughts will be greatly appreciated.
Cheers!
Message 1 of 35
(4,052 Views)
Hi jmcbee,
Do they have to be done seperately? Are there restrictions to doing it in one function?
Unfortunately, I couldn't open your vi's, which are in LV8.5 (I don't have it installed on this PC)..
Can you post an image of the code or in LV8.2?
Or if it's ok to combine into one, I could prepare an example..
Message 2 of 35
(4,038 Views)
The logfile is attached....
Message 3 of 35
(4,037 Views)
Can you save the vi's as LV8.2?  I'll be able to look at it and use your log file..
Message 4 of 35
(4,031 Views)
The sub vi's do not have to be sub vi's, I will try and get some 8.2.1 up for you.  Thanks!
Message 5 of 35
(4,030 Views)
Attached are the 8.2 versions.  Thanks in advance!!
Message 6 of 35
(4,027 Views)
If you use the built-in Search and Replace String function, it will work much, much faster than your subVI.
Message 7 of 35
(4,022 Views)
In place of the Search and Split String.vi ?
Message 8 of 35
(4,020 Views)
Thank you for the reply Dennis,
Could you explain why it will be faster?  I will be a better programmer for it!
Cheers!
Message 9 of 35
(4,020 Views)
Because it doesn't require you to do all of that string concantanation which can be enormous performance hit on long strings where memory allocation has to keep taking place. Just try it and see for yourself.
Message 10 of 35
(4,006 Views)
