I need help with XY graph (about colors of the plots)
Hi have a XY graph on which I have to plot many plots. The number of these plots is VARIABLE and I cannot keep it fixed. The problem is that Labview by default gives to these plots DIFFERENT colors.
My request is the following: is it possible to force Labview to give to me the SAME color for ALL the plots without going to change them by hand from the front panel?
And how? I spent a lot of time to figure it out since long time ago, but I was never able to do that.
Thank you in advance
(2,640 Views)
Accepted by topic author gnappo
You need to use property nodes.  See here.
http://www.medicollector.com
(2,635 Views)
