I need help with event structure. I am trying to feed the index of the array, the index can vary from 0 to 7. Based on the logic ouput of a comparison, the index buffer should increment ?
I am trying to feed the index of the array, the index number can vary from 0 to 7.
or decrement every time the output of comparsion changes(event change). I guess I need to use event structure?
(My event code doesn't execute when there is an  event at its input /comparator changes its boolean state.
Anyone coded on similar lines? Any ideas appreciated.
Thanks in advance!
(2,483 Views)
You don't need an Event Structure, a simple State Machine would be more appropriate.
There are many examples of State Machines within this forum.
RayR
(2,481 Views)
Hey aBM26,
Here is some info on Event Structures and State Machines.
Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
(2,454 Views)
