I use the array to spreadsheet string to take in the data, then I concatenate the date/time string to the end of the spreadsheet string, then I use the write characters to file vi. When I look at the data sheet I saved it under, the data is correct along with the date/time, but the data needs to be in floating point mode instead of whole intergers.
